Barnman951
- Mar 20, 2017
- 2
I need to remove the flywheel. The flywheel has four holes on the top, but only two are tapped. These two tapped holes are on the same side of the flywheel. I'm afraid that if I only use the two holes with a puller, that I will damage the flywheel. Any suggestions on how to remove the flywheel.
