So I've got an 85 johnson 15 horse. I bought it from a guy who had not ran it in years. i replaced the water pump, fuel pump, rebuilt carb. my question is where exactly does the water exit this motor? ive got water coming out the tell tale, water coming out from the vents above the water intake vents along with exaust, and a solid stream from the hole port side on the front of the lower unit. I ran it for about 10 minutes this afternoon and the water coming from the tell tale and the small hole in the lower unit are cold. the water coming from the vent with exhaust is warm, but does not seem like much water is flowing when compared to the other two areas. does this sound normal? should I have water from the prop? it is a through hub exhaust.
