gnarbrah
- Sep 20, 2007
- 140
Hello all - I finally dug my 6R75R out of the shed again and am trying to get her back on the water. I pulled the carb and cleaned it even though it was spotless and just went out to try and start it with some fresh ethanol free fuel. Good news is it fired up after a few pulls. The bad news is it only ran for a few seconds then dies. As I looked around I noticed that the fuel pump cap / cover has a crack in and fuel was leaking out. Question now is should I just replace the cap or the whole pump assembly? Looks like I can get the cap for less than $10 but the whole pump is $50 or more.
Also, would a crack in that cap cause it to die that quickly or am I looking at something else too?
Thanks!
Thanks!
