Hi all
87 25hp Johnson. I had a thread on getting it idling but am starting a new one because I played with it again today.
http://forums.iboats.com/forum/engi...oards/10335736-1987-evinrude-25-hp-idle-issue
What I know.
Compression in both cylinders 95 psi
Good spark
New spark plugs gapped at 0.3 inch
Fuel pump ok
Carby clean as a whistle
When I bought it the carby float was upside down. It is now up the correct way up and parallel to base of carby
When idle circuit screw fully seated I can still blow air through circuit (I thought this should not happen)
The butterfly has to be slightly open to get it to idle
Exhaust was coming from the base of the power head near where what looks like a crankcase pressure hose is connected.
The motor never idled but went like the clappers. I tried to get it to idle by linking and syncing and lost top end. It went downhill from there.
Anyone able to suggest where to next? Reeds? Sorting out idle circuit? Timing? Is there an idle timing suggestion? None is listed in manual.
Thanks in advance.
What I know.
Good spark
Fuel pump ok
Thanks in advance.
