hello and thanks for all your help.could not do it otherwise.my handle was my occupation for 40 years,nothing to do with outboards! not savvy about the internet and how to join this forum,either.i'm just barely scraping by. today checked compression, it's about 63 on both cylinders, is that ok? pee hole spits water,some anyway.motor does not really get hot but will address that later.had the motor running for about 15 mins. last time i removed the shutoff valve, did not see a filter in there but will check again.if there is one,don't know if i'll be able to melt the solder.by the way,what is that red dope on the shutoff valve? modern version,please.also, there is mention of a sealer 1000 in my 67 service manual .what would that be in a modern version? you're supposed to put it around the outer edge of the welch plug.is that before you put in or after you put it in and flatten it? i'm pretty sure when i did my carb for the 3rd time and sealed the welch plug with household glue that did the trick because before motor wouldn't start at all .had it running today but motor was vibrating while idling ,not smooth like it should be.with all of you helping me i'm sure i can do it.again,thank you all
