Speakrdude
Ensign
- Feb 25, 2004
- 942
So, I was having problems earlier that prevented the engine from exceeding 2500 rpms. After changing a coil, power pack, and checking all the normal things, (sensors, et.) It was running around 5500 rpms, but was idling too fast. So I loosened the +- screw holding the tabs down on the flywheel cover and lowered the - down to help slow down the idle. Put the boat on the trailer and forgot about it for a month or so. Now, took out, will not go over 3500 rpms, sounds like a short or something? Did I change the timing by lowering that tab setting?
