JoeFromAkron
- Jul 30, 2012
- 144
So I recently got a 35 hp Johnson 35EL78R. The electric choke didn't work becasue of corroded contacts on the choke switch so I just got a new push to choke switch. That works great. I also got a safety switch becasue it didn't have one. I am getting confused on exactly how to wire up the safety though. The one I got has two M poles and two S poles. I know I am supposed to use the M poles but am not exactly sure how to wire it in. I am thinking I am supposed to put it between the same wires that go to them M poles on the ignition switch? Thing is, the colored wires on my harness don't match the wiring diagrams.
I know this is a simple thing, I've just never done it before. The picture is what I have. I had already taken off the lead for the battery that was red. The little purplish cable there is going to the choke switch from the A pole and the choke lead was Purple and white like it should be. So on the new ignition switch I have nothing on the A pole. I dont have the cable for the tachometer I've seen in a bunch of diagrams. I am thinking I am supposed to put the safety between the Blue and the Blue/White wires for my particular setup but I wanted to ask first.
My Plan is to just get some wire and screw terminals and connect either end to the M poles on both the switch and ignition and that will give the ground to stop the motor if I fall out.
Thanks for any guidance. I know this is simple stuff I just don't want to fry anything because the motor is perfect.
Joe
Joe
