norcalauto
- Mar 17, 2008
- 6
I have a 1982 75 hp evinrude model number E75ERLCNB. I failed a pressure test in the lower unit and decided to replace all the seals. When I pulled the water pump and driveshaft bearing carrier I found that my driveshaft was extremely pitted and rusted so the new seals would not seal. I ended up buying a new driveshaft. Now I need to shim the new driveshaft.. I cannot find a part number anywhere for the shim guage bar for this outboard. Can anyone please help me with this info??
