I have a 1995 Johnson 115 2-Stroke, takes a little choking and priming to get if started but once it is started I can turn it off and it will start right back up with no problem. The problem is when it is at WOT after a couple minutes it will slowly start losing power until it goes down to about 1300 rpms and then it I try to give it more it will bog down and shut off. It will start back up and go into gear but right when I give it throttle it bogs down and shuts off again. I have removed the carbs and they are spotless, also removed he float bowls to make sure they were not gettin stuck and they are moving up and down freely
