Glassman87
- Jan 17, 2017
- 12
Have a 1984 Johnson 140. Spent alot alot of time reading here and everywhere on converting to old style fuel pump. I see the kits to.hook pulse line up ECT. But the 84 has its pulse line in the exact spot that the 83 I have with a regular pump.on it now on each side of the pulse line are two screw holes looks like maby all they did was tap and thread a fitting in and attach hose my question is has anyone went and bolted the pump from.a 83 to the block if so do I have to mods that pulse hole or just remove fitting and bolt on?
