I have the "Evinrude Johnson Service Manual 1971-1989 1-60 HP" that I believe I purchased from this site. On further review the disconnect I mentioned is for the shift linkage. However, under water pump removal, the "advice" section reads "If the only work to be performed is service of the water pump, be extremely CAREFUL to prevent the driveshaft from being pulled up and free of the pinion gear in the lower unit... If the shaft should be released from the pinion, the lower unit MUST be disassembled to align the pinion gear and drive shaft, then the driveshaft installed. The "good words" section immediately following refers to a driveshaft key indexing to a keyway on the pinion. That is what I erroneously referred to as "timing." So, if complete lower unit disassembly is required for seal replacement, I should not worry about the advice on driveshaft removal as I should have adequate access to match up the key and keyway, correct? That service manual is pretty good, but covers too many models to go into as much detail as I would like on this particular task.I did some sleuthing on YouTube, but I didn't find much there useful to this specific job either. I hoping that I can put together the instructions from the manual, parts diagrams specific to my motor, and what I see when I open up the lower unit to get this task done correctly.
