Hi guys.
Getting ready to install a gearcase extension on my 88 Evinrude 25hp to extend it to 20" and I'm trying to get a handle on the procedure. I have the full extension kit, including housing, longer water tube, drive shaft, and shift rod.
One person said you have to remove the powerhead to make this conversion, while others have said you only need to remove the lower unit to swap the parts. I would definitely prefer to avoid removing the powerhead if possible, but just by looking at it, I'm not sure how I'd disconnect the water tube or shift rod without doing that.
Can anyone shed some light on this? I don't want to make this job more difficult than it needs to be.
Model # E25RCCA
Serial# 732740
Model # E25RCCA
Serial# 732740
