GeeTee
- Jul 14, 2014
- 20
Hi Guys - i have just recovered from a mid lower unit leak - where the powerhead meets the mid unit housing. New gasket etc. While i was at it i replaced the head gaskets, torqued the bolts, no leaks. When i run the engine i get a strong water stream from the pisser however, the starboard head gets extremely hot. The port head is cool - i can put my hand on it no problem, starboard not so much. I get no overheat alarm but can tell the head is hotter than what it should be. I have removed the thermostats and completely swapped them around, port thermostat to starboard and vice versa. Same problem. Its gets pretty hot pretty quickly, around 3-5mins and this is at idle.
Do i have water restriction or is there somewhere else i can look?
No ive not done a compression test, do i need to?
