Success! Motor seems to be running perfectly, with the exception of the only way I can get it to idle and go up to high-speed is if the high-speed needle is out only 1/8 of a turn. And I mean 1/8 of a turn, anymore it's stalls any less obviously it doesn't get fuel and stalls as well. Once I get her on the water I'll see if I have any issues with the high-speed. Sidenote , wasn't pumping water when I got it, but all of a sudden the impeller seems to have jarred loose and now I'm getting good water flow. I bought a seal kit And a new impeller, after I test it on the water maybe I'll get to work on that. Thank you for all your help.
