BlackoutBill21
- Dec 10, 2016
- 175
ok, after much searching, Ive finally decided to post... I own a 1955 evinrude fleet twin 7.5 hp 18902D that I've converted to a singe line fuel system.
New coils, plugs wires, confirmed spark, carb (taken apart and cleaned with cleaner / compressed air) . It starts and will run with slow speed needle out like 7 turns, and full throttle but it barely stays running. When i did the conversion I plugged the right side of the intake manifold hole. The video on youtube starts plugging one side then switches to the other side. My first question is does it matter which side you plug?
Second, I installed an inline fuel filter. Could the location be preventing fuel from reaching the carb? Its located after the primer bulb before the connector.
Third, The connector at the motor leaks fuel a little.. Ive been informed that most do.. its an old connector so should i replace it?
Any ideas why the rough idle? barley stays running unless the throttle is full but it will continue to run rough if i do.
side note, I've done extensive research on how to break down this carb however I will note that i didn't buy a new kit or replace and clean out the metal plugs that have to be punched out. I know my luck and highly doubt its something as simple as a clogged jet. But if you buys without a shadow of a doubt tell me its carb related then i will break it down again.
