I just replaced the fuel pump (non-VRO conversion) and the in-line fuel filter. Because of the different location of the fuel inlet to the pump, I positioned the filter in the vertical portion of the fuel line. Originally, it was positioned horizontally. After pumping the bulb, the motor starts right up, but only runs a short time then stops. After this happens I have noticed that the fuel level in the filter is not quite full as if the siphon action can't handle the increased diameter of the filter(?). Should the filter be repositioned to a more horizontal position to help the suction flow of the fuel? Or do I have another problem?
