Re: Evinrude nuetral safety switch
I have a 1994 Johnson 150 FastStrike that exhibits some of your same problems. I have never had it fail to start on the driveway or in the water when it was cold. After I have run it for awhile and stop to fish, (sometimes- not always) it will fail to engage the starter or even make a clicking sound. The only noise you hear is when you turn the key and the warning horn sounds off to let you know it is working. I had the dealer replace the neutral safety switch and that did nothing. I replaced the ignition switch last fall, but don't believe that will solve the problem. My next move is to replace the starter solenoid. I always can get it to start by turning the key off and on several times, but one of these days, it will leave me stranded unless I find the problem. It has been this way for about 6-7 years. Good luck on finding your problem Hopefully yours will be the neutral start switch.
