My 1970 60hp johnson has a warning light on the control box if the engine gets too hot. I am in the process of adding a tell tale (thanks for the help with that guys) but I want to make sure that the warning light works too. I have located the switch (item# 74) on the power head group and it looks like it is mounted underneath the cylinder head cover.
Can I just apply some heat to the side of the cover near the switch to see if the light come on? At what temp should the light come on? I am thinking of applying small amounts of heat with a torch until the light comes on unless that is a terrible idea. If it is a terrible idea, how else would I test it without taking the cylinder cover off?
Thanks
Thanks
