Glassman87
- Jan 17, 2017
- 12
Ok new here and looking for some knowledge. I have a 1984 Johnson 140 hp (j140txcrd) it's a 25"shaft i got it real cheep. The power head and all is in great shape has perfect compression ect. I want to make it into a long shaft or 20" as I have no use for a extra long 25". I have a 1978 115 I can get for 250$ it's a Johnson 115 (115etl78c) my ? Is can I take my 84 140 power head and swap it on the 78' 115 midsection down. I've researched part numbers their is alot similar but not sure if it's as plug and play as I think.or if it's doable the drive shaft exhaust gasket and shift rod are all matching part numbers on omc but the exhaust housing adapter is diff part number. Any help would be greatly appreciated
Thanks in advance
Thanks in advance
