johnboy65
- Jul 22, 2015
- 10
Does anyone know what the correct length of a #376073- Johnson Pinion shaft shock absorber should be? Do they expand in length when the interior spring breaks and is there a way to check them before you purchase or install a replacement? I own a AD-10 that runs like a champ until you give it some throttle and then it acts like a spun hub.. I've tried just about everything to get this motor to push so this is my next stab at it..
