gahunter706
- Jun 3, 2013
- 82
I have a 2006 Johnson 90hp that I keep having an issue with the carb bowls warping and leaking. All 4 bowls were slightly warped and leaking when I purchased the motor, so I rebuilt the carbs and put new bowls on them. That lasted for a couple months, then they slowly started warping again and leaking. I ended up taking it to a dealership to fix it because I just didn't have the time to mess with it, as well as the motor having an ignition problem I couldn't figure out. They rebuilt all 4 carbs, put new bowls on them, and replaced the power pack and the key switch. Motor ran great for little over 3 months, then the carbs yet again started warping and leaking. Is there a way to keep these carb bowls from warping, or maybe a metal replacement for them? I had read that over tightening the screws on the bowl could cause it to warp, but I made sure to torque them down to spec, which I believe was in the 20 in-lb range, when I rebuilt the carbs the first time. Any help would be greatly appreciated.
