Hello,
Im new here, so first of all hi there!
Second I have a problem and maybe you could help me. Some mechanics checked but couldn't tell whats wrong.
So, I have an Evinrude 235hp ~1983 (E235TRLCNE). When its cold its all good its smooth and strong and fast, but just for the first 15 min. When it gets warm it lose power. Some of the cylinders cuts off, can smell petrol. Doesn't rev more than 1500rpm, If I try go more, it dies. Then starts easy again, but still doesn't rev - no power. On neutral it works ok, does rev, but in gear other talk...
So far: fuel tank cleaned, new fuel filter and water separator. So no water in fuel. (also it wouldn't explain why it happens just when engine is warm).
Carbs were dismantled and cleaned - looks ok. Fuelfilters checked - looks ok. New spark plugs. Mechanic checked and said that coils are ok too. Compression is good.
Maybe some one could help? Dont know what to check else, how to check? Or what to change...
