shooter5636
- Aug 7, 2015
- 27
You guys have become my go-to resource for this motor. These questions may be a pain, but I learn something from this community every time I post a question.
So I need some help with the throttle linkage and if it is in sync or if I need to reset everything. I've tried following the service manual for it, but I learn and understand better by seeing, and it's pretty limited on picures. I've been having problems with the motor ever since I brought it home. It wouldn't idle for me. I ended up getting the idle adjustment worked out and the RPMs sitting nicely around 900 but the needle valve is currently adjusted out something like 4.5 turns..... The motor says the starting point is 1.5. The motor would have a mean lean sneeze if I tried to lean the mixture up at all. If I choked it out, the lean sneeze would go away. Are some of these motors just that thirsty? The motor accelerates as it should all the way to WOT.
Pictures of throttle linkage:
The throttle has to advance this far before the butterfly begins to open:
