1969 6hp fisherman
jonsilva
I have a 1969 evinrude 6hp fisherman. It starts and runs really well in neutral. I put the motor on my 11' flat bottom boat and when i put it in gear it does not want to rev up. it only goes just a little past idle even when i turn the throttle to full speed. i can tell that it wants to rev higher because it does for a split second and then drops back down. when i leave it a full throttle you can feel the motor trying to rev up but it never does. any ideas on what this could be?
Step # 1 is to check spark intensity.-----Does spark jump a gap of 1/4" or more.------Classic symptoms of running on one cylinder.-----When I pick up one of these motors it usually has new coils already.
Well, ---A motor like that will rev up " nice and high " running on one cylinder.--Your test means nothing here !
Often folks do not want to do testing.---I could show you some coils all cracked and with a hole burned through the bottom.-----So does spark jump a gap of 1/4" or more , yes or no ???
Pull one wire off and see if it will start.---Repeat with the other wire.----With motor running remove wires one at a time and see what happens..
jonsilva
ok will do this and see what happens, what should i do if it turns out one cylinder is dead?
Pull the flywheel with the correct puller and inspect coils.---You may find 2 cracked coils or 2 new ones already.---See this all the time.
jonsilva
checked the spark and the bottom cylinder has no spark at all, the top cylinder has plenty of spark, do i have to mark the position of the flywheel before taking it off ?
F_R
No you do not have to mark anything. But you do need the correct tools and do the job properly, or you can ruin your motor. You need a flywheel puller (a harmonic balancer puller will do) to get it off. DO NOT use a puller that grabs the outside diameter of the flywheel. When reinstalling, the flywheel and shaft tapers must be clean and dry, and you must use a torque wrench to tighten the nut to 40-45 foot pounds. You also need some sort of a tool to hold the flywheel when torquing on it (strap wrench). There are several You tube videos on the job. A guy named cajuncook2 has some good ones.
