What racerone said. Yes it is the pulse line, and yes it normally operates at about 5psi. Except when it lean sneezes. When that happens, it will blow a hole in the hose unless it is the correct stuff. I've seen lots of them rupture back in "the day". The original hose had fiber reinforcing strands molded in. And yes, it needs to tolerate gasoline & oil.
