Can my e50tleuc model 50hp evinrude be converted from electric solenoid prime to manual prime? There is a part available it says for that model. Also on the fuel connection point at the motor what is that extra end piece that is plugged off. It sits directly under the fuel hook up at the motor on exterior of cowling. I was thinking that is where the manual pump would install to. Thanks for any help guys
