garland gaston
- Sep 28, 2016
- 8
I replaced the water pump (kit) on my 15 hp kicker outboard motor. Seemed fine after replacement. Water coming out witness hole. Operated good for total of about 4 hours, over several uses. Then I noticed a different sound, and no water was coming out witness hole. I shut engine down. After pulling water pump, I found the impeller badly damaged, like it had been running without water, sort of burned. The assembly seemed correct. What is your best guess on what happened? I'm afraid I now have bits of impeller rubber in the power head. Is there an easy way to check this without major dis-assembly?
