1968 Johnson 20hp Not pumping water. New impeller, tstat, unclogged water port.
sparkplug619
Hello. I have a 1968 Johnson FD-22M 20hp.
I did a complete tuneup on the boat, ignition, fuel pump, fuel tank clean, water pump impeller, tstat, lower unit oil, carb rebuild, tapped in a telltale 'pisser'... everything
took it out all day yesterday, it was pumping water perfectly for the hours I had it on the water. Ran perfectly. I let a buddy of mine give it a go, everything was good until he jumped from forward straight to reverse when trying to shift into neutral. He killed it and we sat for awhile arguing over what the hell he just did. upon firing up, everything was moving and grooving but it was no longer pumping water. I decided to paddle a 1/4 mile to the dock with 1 small oar.
Today I pulled the lower unit. everything looks OK, the gearcase is OK,waterpump and impeller OK, Tstat OK, water port OK. Ran water from the tstat housing and it flowed freely out the bottom.
I have no idea what else I should be looking for. Please HELP
sparkplug619
when I had it apart it seems OK.... also if the driveshaft was broken wouldnt it not.... drive?? I fired it up and it drove but killedit when i noticed it wasnt peeing
interalian
I didn't catch that it would still drive. Can't see how the key in the impeller would shear, but perhaps the sudden jolt of F to R did it.
sparkplug619
No Title
Exactamundo...... looks like im spending my last week of vacation waiting for parts to arrive :(
anyone know the exact diameter of this pin? maybe I can find one at a parts store or home depot
tomhath
Master Chief Petty Officer
The pin usually comes with the impeller. Maybe look in the package to see if you overlooked it.
sparkplug619
I replaced the pin with the impeller but ive long since discarded the old pin...
I went to home depot and found a couple bits in the chain and hitch section. Brought em home, found the best fitting one, ground it to size and had another magnificent day out on the water!
sparkplug619
No Title
Heres what i used to cut down to size... and heres a cool little before and after of my boat.... thing had holes and leaky seams and rivets. Now its 100% solid thanks to some gluvit and 3M 5200
interalian
Is that a stainless "S" hook? If not, you may wish to change it to an OE pin before too many hours, especially if you're in salt.
sparkplug619
It is stainless but I already have the original pin on order. just wanted to enjoy the boat while I have my last week of vacation from work
