Speakrdude
Ensign
- Feb 25, 2004
- 942
So, all of the sudden, (after I recently changed the oil tank, plugs, new "gray" wires.) Took it out (double oiled, just in case)
Ran great all day!
Then, a couple of weeks later, I replaced all 6 leaky carb bowls. Yes, I bled the oil line.
Every once in a while, over the years, I would get a low oil or fuel psi warning every once in a while. (beep 1/2 sec., every two seconds, faster with higher rpms) Turn off, restart, goes away for the day, Typically.
But now, after disconnecting both temp sensors, and verifying water temp, still seems to be in S.L.O.W. mode. So I've ordered and received a new power pack, but have not opened the box yet.
I decided to do some more testing with my DVM today, (diode etc) and after disconnecting/removing, all three of the dual coils, I've discovered that one of the coils is reading 2500 ohms from primary to secondary, either direction, and all 5 of the other coils read 280 ohms. I am about to order a new one but wanted to hear some other opinions, just in case. I suppose if it was only running on 5 cylinders, maybe the S.L.O.W. circuit would kick in or just run lake crap anyway?
Thanks,
Jim
Ran great all day!
Thanks,
Jim
