Working on a 1992 Evinrude 175 HP I am looking for the other end of an intake hose location starboard side. Behind the carburetor is a black plastic mount for the carbs or functions as part of the carb(s) on the port side a hose leaves this mount on the side of the engine port sides, runs dirrectly down to the base of the motor and then heads to the starboard side , the black piece that runs behind all the 3 carburators on each side of the engine, could be called a plenum, and the hose goes to the front of the motor base of the case and is pushed on to a nipple on the port side front at the base of the crankcase. I figure this hose senses vacuum and pressure in the crankcase and us used to equalize pressure and vacuum between all carbs. The other port side of the engine has this same set up but the far end of the hose, though it is long enough to reach the port side is broken at the end and I cannot figure out where it mounts to. Can someone show a diagram or a picture the same motor showing where this hose terminates. I tried to upload pictures but it wouldn't allow it. said wrong file type were jpg.s. Or maybe someone has hose diagrams for this they can share of not pictures. Thank you very much for any help people can offer. I hope I posted this in the best place. If not, I am open to suggestions. This is my first time posting. Thank you, Alan
