Raul Esteban
- Mar 26, 2005
- 14
Was running great but decided to do my yearly tune-up,de-carb, filter...ect.... Marine store gave me wrong plugs at first. (for venom) replaced with correct ones.<br />Now it has a ticking sound (sounds like a car with a bad lifter) Runs strong and fast at WOT 5600 RPMS. no ticking noticed until lower rpms and at idle. Will not run at idle for long time at dock. New VRO pump,new gas. All that has being described only and only happens at dock in water. No ticking or idle problems with muffs.<br />Compression test shows 105,110,105,105,110,105. Spark test is okay. Alarm has gone off at idle a couple of times. I am thinking alarm sendor in deffective and puts motor on low and shuts down at idle. What is the ticking?? What happened? I was out all day saturday and had no problems except for ocassionally shut down at idle and started right up and of course the ticking at idle and low rpms.Other than that ran hard,strong and fast.<br />Any thoughts??
