EHardgrave
- Mar 25, 2005
- 56
We are switching our older 91 Johnson wiring to a 2002 Johnson 4 stroke. Purchased the adapter harness and the system check gauge. After review of Seloc and this site I have determined I think, the purple wire is positive. Is this always the case? The reason I ask is it had a loop solder less connector on it like for a screw to go through. I know grounds are usually black so does this ground back at the motor then? Also branching off of the 8 pin connector for the gauge is a 2 pin connector also a purple wire and I dont remember the other color. What would this go to? Thanks for your help.
