70 hp evinrude engine noise then quit
elkbugler
70 hp evinrude was running fine across lake, then motor started to make noise .we pulled back on throttle and motor quit. we could get motor running with cold start lever up . motor stall when cold lever is down. is there something under flywheel that would possibly let loose
