andrew j miller 04-16-198
- Apr 4, 2004
- 2
Hey guys,I have a few questions..I recently got a 1976 15 ft thundercraft Titan with a 1977 70hp evinrude,runs great with muffs on it ,I don't know much about boats in general but I am mechanical,...?1 is there some kind of warning buzzer that is sapose to sound when the switch in turned to the on position? Also leads to my next ?...the ignition switch is hooked up wrong!! The kill is in the choke...when I turn the key off it stays running,I have to turn the key back to run and push in on the key to shut the engine off,and I'm sure it's not choking it to stall out,the server for the choke don't move at all..can someone help me find the wiring diagram I have a older evinrude power pilot unit as well...thanks for your time
