I just bought a Evinrude 50 HP outboard model # 50272c . It runs well , but does not shift into reverse. I checked the wiring and both the green and blue wires are hot when I push the reverse button as they should be. I also checked the ohms on the solenoids and the are at 6 ohms as they should be . The motor shifts into neutral fine , just not reverse. I pulled the low end , checked and set the placement of the plungers in the solenoids , flush at the top . Any ideas on what else could be wrong ? it seems to me that if the pump was bad I would not have neutral , but perhaps that is not so .
