Hi guys!
So I purchased this 1963 Evinrude Sportwin 10hp from Craigslist last year to use on a little 14' aluminum boat for some casual fishing in my area.
When I visited the owner, he said the motor was his grandfathers and had sat in a garage for most of its life. I believed him because to be honest it was one of the cleanest looking 1960-1970 era motors I've ever seen. He used it for some casual fishing and would frequently rent John boats but never owned a boat to use it on himself.
Anyway, he pulled a bucket over and started her up for me. Took him just a few pulls and she started up. The motor idled fine and throttled fine. After a few more questions I decided to bite the bullet and buy the motor (was a great deal at 500 bucks). Came with original Evinrude gas tank and everything.
I brought the motor home and a week later I mixed together a 50:1 mixture of fuel and test ran her in my driveway. She was a little difficult at first but did start up. I wouldn't say she ran perfect but she did run.
I did notice some thick blue looking oil leaking a bit from somewhere in the driveshaft (couldn't tell where because it just made its way down to where the propeller was).
I didn't think anything of it and proceeded to pack the motor up and lay it in the back of my truck. Brought the motor up to camp and put her on the back of my 14' John boat.
I got her into the water and then went on to try and turn her over. It took a bit of effort but I got her fired up and went on my way. FIRST thing I noticed is that the motor lacked high end power. I got up to low-medium speed and that was all she would give me at full throttle.
In order to not ruin my friends time I just continued to use the motor in this condition for a few hours.
The motor stalled. I got her running again but she eventually stalled once more. This time I couldn't get her to turn over again. Had to be towed in by a neighbor.
I was very upset and the next day decided to tinker with it and try starting her again.. Nothing. Eventually after trying to start it for about an hour I finally got it running.. But again, no power and the motor would just bog and then die.
So that's where we are at with symptoms.
I took the motor home and it sat in my garage for about 6 months.
I am going camping in 3 weeks and decided to try and get her running properly.
I briefly did research on outboards (I don't know too much to be honest) to find out where to start and how to diagnose the issue.
I noticed the fuel filter was very very orange/brownish in color and there was some orange/brown crud stuck to the bottom of the glass bowl the filter sits in. I removed it and cleaned it and am waiting on a new filter I ordered to come in the mail.
I checked the linkages on carb/connections/fittings all around the motor and it all seemed fine. Rubber gaskets around carb/fuel pump feel sturdy/not worn.
Today I pulled the plugs for the first time and they were surprisingly clean. Virtually no black residue on them at all. (I think the previous owner said he replaced them). But still, they were bone dry and hardly even smelled of gas or oil. Although, the motor hasn't run in 6-8 months so I figure maybe that's why.
While the plugs were out I did a compression test on each cylinder. The top cylinder read at 65ish-70 psi and the bottom cylinder read 80 psi. At first this sort of freaked me out but I want to know what you guys think. Is that expected of an older engine or am I looking at a serious issue beyond my own repair?
So that's all I've done so far. I plan to replace the gear lube this week, put in the new fuel filter, replace the spark plugs, and try to start her again since last time I was on the water.
If she still won't start, what else could it be? I was planning to look at the fuel pump next and see if I could clean/rebuild it but I hear you might have to just buy a new one with these older engines because when you take them apart they're ruined?
Also, I'd like to address every problem I can without taking the carb apart since that is a more daunting/tedious task (not to say I'm not willing to or that I can't do it, I've already found the rebuild kit I think).
Please let me know what you guys think!! I'll post pictures and maybe even a video as soon as I can! Thanks!
