Recently rebuilt VRO2 due to engine starving. Found the gasket was torn. replaced fuel line etc. Accidentally put blue pulse in backwards but fixed that. Still is being starved of fuel. Took off pulse limiter hose from bottom of air box to feel for pulsating air from block... there was. Noticed fuel leaking from hose and bottom of air box. Primed the bulb and more fuel came out from air box.Is that normal?? BTW compression on cylinders are low at around 80lbs each. Thanks so much as i am frustrated beyond belief!
