Old P'Tooner
- Aug 2, 2009
- 10
35EL78R, Bought a 16' Crestliner recently knowing the starter was bad. Or at least that was what I was told. Would not turn over w the plugs in. Ok fine bought a new starter installed it one wire at a time, so no cross wiring could happen - Nothing, same as when he delivered it. Ok, maybe its the solenoid ,one wire at a time, so no cross wiring could happen , Done - nothing. hot jumped the sol. to the first small stud - Nothing, (old hotrod guy, so I've jumped more than on Ford that way) BUT when I jumped the starter side to the hot side of the sol. (big studs). VIOLA! popped off and ran Key does nothing, but turn on the ign. No cranking, checked all the in line fuses, (2) and replaced them just to be safe- Nothing. What the Heck?
