My engine runs but it isn't spitting out water like it is supposed to. I see the exhaust coming out of the hole in the shaft and I believe the water is supposed to come out of a little hose right under the cowling. Correct me if I am wrong. I ran it for a while to see if it needed to heat up in order to spit water but eventually exhaust started coming out of the little hose and it dropped a couple drops of water. What do I need to do to fix it as for I am a first time boat owner. Thanks everyone!
