Ok. I have a two questions. I know you guys would know what the possible diagnosis would be. When I don't know when I will be able to take the boat out again. I have always been told to burn the remaining fuel in the carb. To keep the carb from Gumming up. When I do so, and try to restart. The only way the motor will restart is by putting small amount of premix directly into the combustion chambers. I rebuild the carb thourly. Still have the same issue. The motor will cold start fine if I don't burn the remaining fuel in the carb. Question one is why is the carb doing this? And two is it necessary to burn the remaining fuel in the carb, when the motor is going to sit for a couple weeks? Any ideas would be very much appreciated!
