Rich Mabrey
- Aug 9, 2016
- 1
This spring I installed new reed valves and blocks, rebuilt carbs and replaced fuel pump. It was running great for 2 months and now it will idle fine and troll fine but I can't get top speed out of it. I am having trouble with getting boat up on plane. Full throttle it runs steady and kicks up big wake but won't go fast and plane out unless I cover top carb with hand and cut air off about 1/2 to 2/3, then it goes fast like it's supposed to. Timing is correct at high end and low end. I took carbs of and cleaned again but no help. Any suggestions?
