Sluggish running at low speed and sudden dying unless I were to pump the primer bulb led me to suspect fuel pump trouble. I attempted to rebuild pump using gasket set, but to fortune I was not able to flip my brain upside down to reinstall the many tiny springs and plungers. So, I ordered a new complete pump from Powersports Plus in Ga. It arrived in only 9 days time after spending time in the wrong PO western Wa. Care fully using new hose keepers and aligning hoses on the new pump ( the box says Evinrude Johnson Genuine Parts, BRP US Inc 0397839 ) so not to stress by torque, I installed with new pump to motor gasket. Well,it solved the running problem immediately, but the pump itself leaks like a sieve from the layers of gaskets of the pump, not the hoses. Question: Have I done something wrong? Is this the type of job which requires a 110$ per hour tech to perform? Motor is '92 Johnson 15 hp J15RENM.
