I believe that primer squirts gas into the carb venturi area. If the motor is tilted forward, it runs the wrong direction (out instead of in). In other words make sure it is sitting level or even back a tad.
F--R You are not only the Supeme Mariner!! You are the "MAN"!!! I am going on vacation tomorrow and Mr. Johnson is going with me. Thank You! bessfirst.
