Anyone know where I can find a really detailed diagram of the tilt and trim cylinder, specifically the cylinder end cap? I need to know the correct orientation of the tilt rod seal inside the end cap which sits below the backup ring. Is the channel of the seal supposed to be facing up towards the backup ring or down towards the cylinder. Thanks in advance for any help.
