Hi All. This is my first post so hopefully I am posting in the correct place. I have a Johnson 30hp 2 stroke on my fishing boat that doesn't seem to want to pump water to cool the motor. I fitted a new water pump kit today, fitted my hose attached to my "headphones" and started her up. There is no water being ejected from Either the 2 vents at the top of the upper leg or the small hole on the underside of the engine casing (pee hole?).
Any help or advice will be gratefully received
Cheers
DaveD
Cheers
DaveD
