NeilDaCosta
- Mar 13, 2014
- 18
Had the boat on the water the other day and both the low and high speed adjustment needles rattled loose. I tightened them on the water and got the motor running but it was real rough and died within a minute.
Pulled the carb off yesterday and realized the packing washers on both adjustments were blown out. Replaced those to according to the manual. And set the adjustments accordingly. Compression is good in both cylinders. I replaced the spark plugs to as they were pretty oily from the bad mixture they were getting.
My problem now is when I try to pull start it (I don't have the electric start hooked up), I don't get spark from either plug.
Any ideas of what the problem could be?
I don't know too much about the safety cut off, but did take the wire off of it and still no spark.
Going to start taking apart the top end this afternoon, but figured I would see if any one had an easy answer of something I am not thinking of.
Thanks!
Thanks!
