Last weekend I was going across some rough water (very bumpy) and once I got out of the wind I noticed that the engine was acting like it was going to stall. I was going along at ~80% open throttle and although it would intermittently "stall", the motor never did die. I noticed that the throttle didn't seem as responsive as normal too. Anyways, we got to our fishing spot and after an hour or so we decided to move. Motor started normally but died as soon as I tried to put it in gear. This happened once more and then it wouldn't turn over. After about 30 mins of looking at the motor it started up and I was able to get to a nearby marina. We took the motor cover off and I could see gas coming out of the little drain hole on the cover over the carbs. I removed the cover and the carb intake piece but couldn't see anything visibly wrong. Reassembled everything and it fired right up and ran like normal until we were within a few hundred yards from home. We stopped to fish once more and haven't been able to get the motor started since. My first thought was that one of the carb needles got stuck in the open position and was flooding out the cylinder. I rebuilt all three carbs last night and took it to the lake to test about an hour ago. I couldn't get it to start but noticed a large gas/oil slick behind the motor. I say gas/oil because I removed the VRO about 10 years ago and have to mix the gas manually. I pulled the boat out and when I trimmed the motor back down gas started running out from around the prop (exhaust?) With the engine off I can't see a leak anywhere but haven't tried looking while cranking yet. Has anyone seen anything like this before? I'd like to fix this myself so I can have a better shot of fixing a problem on the water in the future but don't want to fumble around too long with this either. Any help would be greatly appreciated.
I'm planning on checking the spark plugs and compression tomorrow since its easy, unless people don't think its necessary.
Thanks,
Keith
Thanks,
Keith
