Starboardlean
- Feb 15, 2016
- 73
Well after getting the fisherman running well, i as not satisfied with the intermittant water flow. So i look at you tube for lower unit removal. I watched highlander marine. Romoved four 7/16 bolts and she dropped an inch. Removed shift shaft bolt. Just like the video. The unit would not drop. Figured I was " disturbing the dirt". So i stood over it and gave good downward thrust with both palms. Bingo. Then crapola. I see a sheared roll pin. The video completly omitted this. Heading to rude dealer for impeller and shear pin. Any tips for reinstall? Thanks guys. Should have inquired first. I notice that i tend get in bind then seek help,versus seek help prior to avoid the bind.I need one those Bill Engvall signs.
