Hello, i have a johnson 50-1975, 4.5meters long boat, not so big. It has been under water and was without ignition, had everything apart and blown clean and warmed it all up, suddenly, I got the spark on both plugs Compression is 10.2KG on both cylinders. (145 psi) It runs poorly at idle precisely you manage to get up the RPM with the hand throttle if you sit for a while. manages to run away if I get max rpm och the lever, then i throw in gear, then it runs smooth and stable, but really tired. was 18 knots at full throttle. This engine with this little boat should do at least 30, I think. Then I removed the cover in front of the carburetors, splashing out more gasoline from the lower carburetor, but still comes from the top, but less. Should it be like this? Then pulled out the upper plug cap. The engine changed a little bit in the run but not much at all. continues to run, I pull out the lower spark plug cap and the engine dies. Have had loose carburetors 4 times and double-checked and cleaned everywhere, had loose reed valves checked cleaned, are now completely without ideas about what it can be. New spark plugs, I have, of course, tried two new rounds .. Almost feels that the engine is running like on 1? cylinder because it barely changed when I pulled out of the cap. Looked after and i do have spark. Any idea what the problem is??On the film is the hand-lever is in full throttle, you can get it to rev up more if you go down and up on the lever. I tried today to spray starting-gas in the upper carburator, but then the engine almost dies. so i think the engine gets enough fuel? I also trying to press the bulb for the fuel but nothing changes. https://youtu.be/kh0ba-NRpQo
