Tony T.
- Jun 5, 2007
- 178
My 1992 60hp Evinrude power tilt/trim will raise the motor up but will not lower the motor,this just happened yesterday . It does not work with the switch that's mounted on the side of the motor to lower the motor or the throttle mounted switch. Like I said it raise's motor just fine with both throttle mount switch and the motor side mount switch. In order to lower it at the ramp yesterday I had to use a screwdriver and turn the manual release screw on the side of the motor to let it down. I had my drivers seat rotated around while fishing and kept accidently leaning against the throttle mounted switch through out the day, could this have burn up the lower down side of both switches or what ?
Thanks for any info
Tony
Thanks for any info
Tony
